Development of a second generation in-flight icing simulation code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Fluids Engineering Année : 2006
Two-dimensional and quasi-3D in-flight ice accretion simulation codes have been widely used by the aerospace industry for the last two decades as an aid to the certification process. The present paper proposes an efficient numerical method for calculating ice shapes on simple or complex 3D geometries. The resulting ice simulation system, FENSAP-ICE, is built in a modular fashion to successively solve each flow, impingement and accretion via field models based on partial differential equations (PDEs). The FENSAP-ICE system results are compared to other numerical and experimental results on 2D and slightly complex 3D geometries. It is concluded that FENSAP-ICE gives results in agreement with other code calculation results, for the geometries available in the open literature.
ASME-JFE-FINAL.pdf (636.56 Ko) Télécharger le fichier
inria-00337571 , version 1 (07-11-2008)
  • HAL Id : inria-00337571 , version 1
Héloïse Beaugendre, François Morency, W. G. Habashi. Development of a second generation in-flight icing simulation code. Journal of Fluids Engineering, 2006, 128 (2), pp.378-387. ⟨inria-00337571⟩
279 Consultations
1458 Téléchargements
