Ontology-guided data preparation for discovering genotype-phenotype relationships - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Bioinformatics Année : 2008
Adrien Coulet
Pascale Benlian
  • Fonction : Auteur
Amedeo Napoli
Marie-Dominique Devignes
Background: Complexity and amount of post-genomic data constitute two major factors limiting the application of Knowledge Discovery in Databases (KDD) methods in life sciences. Bioontologies may nowadays play key roles in knowledge discovery in life science providing semantics to data and to extracted units, by taking advantage of the progress of Semantic Web technologies concerning the understanding and availability of tools for knowledge representation, extraction, and reasoning. Results: This paper presents a method that exploits bio-ontologies for guiding data selection within the preparation step of the KDD process. We propose three scenarios in which domain knowledge and ontology elements such as subsumption, properties, class descriptions, are taken into account for data selection, before the data mining step. Each of these scenarios is illustrated within a case-study relative to the search of genotype-phenotype relationships in a familial hypercholesterolemia dataset. The guiding of data selection based on domain knowledge is analysed and shows a direct influence on the volume and significance of the data mining results. Conclusions: The method proposed in this paper is an efficient alternative to numerical methods for data selection based on domain knowledge. In turn, the results of this study may be reused in ontology modelling and data integration.
inria-00338669 , version 1 (13-11-2008)
Adrien Coulet, Malika Smaïl-Tabbone, Pascale Benlian, Amedeo Napoli, Marie-Dominique Devignes. Ontology-guided data preparation for discovering genotype-phenotype relationships. BMC Bioinformatics, 2008, 9 (Suppl 4), pp.S3. ⟨10.1186/1471-2105-9-S4-S3⟩. ⟨inria-00338669⟩
103 Consultations
0 Téléchargements
