Computing Largest Circles Separating Two Sets of Segments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computational Geometry and Applications Année : 2000
A circle C separates two planar sets if it encloses one of the sets and its open interior disk does not meet the other set. A separating circle is a largest one if it cannot be locally increased while still separating the two given sets. An Theta(n log n) optimal algorithm is proposed to find all largest circles separating two given sets of line segments when line segments are allowed to meet only at their endpoints. In the general case, when line segments may intersect Omega(n^2) times, our algorithm can be adapted to work in O(n alpha(n) log n) time and O(n alpha(n)) space, where alpha(n) represents the extremely slowly growing inverse of the Ackermann function.
bcduy-clcst.pdf (203.59 Ko) Télécharger le fichier
inria-00338701 , version 1 (14-11-2008)
Jean-Daniel Boissonnat, Jurek Czyzowicz, Olivier Devillers, Jorge Urrutia, Mariette Yvinec. Computing Largest Circles Separating Two Sets of Segments. International Journal of Computational Geometry and Applications, 2000, 10, pp.41--54. ⟨10.1142/S0218195900000036⟩. ⟨inria-00338701⟩
157 Consultations
467 Téléchargements
