A formal specification of the Fractal component model in Alloy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This report contains a formal specification of the Fractal component model using the Alloy specification language. The report covers all the elements of the (informal) reference specification of the Fractal model. It provides a truly language-independent specification of the Fractal model, and lifts the ambiguities of the reference specification.
Fractal-Alloy.pdf (268.42 Ko) Télécharger le fichier
inria-00338987 , version 1 (15-11-2008)
  • HAL Id : inria-00338987 , version 1
Philippe Merle, Jean-Bernard Stefani. A formal specification of the Fractal component model in Alloy. [Research Report] RR-6721, INRIA. 2008, pp.44. ⟨inria-00338987⟩
657 Consultations
652 Téléchargements
