A simple pressure stabilization method for the Stokes equation
In this paper, we consider a stabilization method for the Stokes problem, using equal-order interpolation of the pressure and velocity, which avoids the use of the mesh size parameter in the stabilization term. We show that our approach is stable for equal-order interpolation in the case of piecewise linear and piecewise quadratic polynomials on triangles. In the case of linear polynomials, we retrieve a well-known idea of using mass lumping as a stabilization mechanism.
Sciences de l'ingénieur [physics]
