Clip Art Rendering of Smooth Isosurfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2008
Clip art is a simplified illustration form consisting of layered filled polygons or closed curves used to convey 3-D shape information in a 2-D vector graphics format. This paper focuses on the problem of direct conversion of smooth surfaces, ranging from the free-form shapes of art and design to the mathematical structures of geometry and topology, into a clip art form suitable for illustration use in books, papers and presentations. We show how to represent silhouette, shadow, gleam and other surface feature curves as the intersection of implicit surfaces, and derive equations for their efficient interrogation via particle chains. We further describe how to sort, orient, identify and fill the closed regions that overlay to form clip art. We demonstrate the results with numerous renderings used to illustrate the paper itself. More at http://artis.imag.fr/Publications/2008/SEH08/
clipart.pdf (4.33 Mo) Télécharger le fichier
Format : Figure, Image
inria-00345279 , version 1 (08-12-2008)
Matei Stroila, Elmar Eisemann, John C. Hart. Clip Art Rendering of Smooth Isosurfaces. IEEE Transactions on Visualization and Computer Graphics, 2008, 14 (1), pp.135-145. ⟨10.1109/TVCG.2007.1058⟩. ⟨inria-00345279⟩
293 Consultations
615 Téléchargements
