stable kernels and fluid body envelopes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SICE Journal of Control, Measurement, and System Integration Année : 2008
Frederic Kaplan
Pierre-Yves Oudeyer
recent advances in robotics leads us to consider, on the one hand, the notion of a kernel, a set of stable algorithms that drive developmental dynamics and, on the other hand, variable body envelopes that change over time. this division reverses the classic notion of a fixed body on which different software can be applied to consider a fixed software that can be applied to different kinds of embodiment. thus, it becomes possible to study how a particular embodiment shapes developmental trajectories in specific ways. it also leads us to a novel view of the development skills, from sensorimotor dexterity to abstract thought, based on the notion of a fluid body in continuous redefinition.
kaplan-oudeyer-sice09.pdf (269.04 Ko) Télécharger le fichier
inria-00348476 , version 1 (19-12-2008)
  • HAL Id : inria-00348476 , version 1
Frederic Kaplan, Pierre-Yves Oudeyer. stable kernels and fluid body envelopes. SICE Journal of Control, Measurement, and System Integration, 2008. ⟨inria-00348476⟩
269 Consultations
201 Téléchargements
