An approach to visual servoing based on coded light - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Positioning a robot with respect to objects by using data provided by a camera is a well known technique called visual servoing. In order to perform a task, the object must exhibit visual features which can be extracted from different points of view. Then, visual servoing is object-dependent as it depends on the object appearance. Therefore, performing the positioning task is not possible in presence of non-textured objets or objets for which extracting visual features is too complex or too costly. This paper proposes a solution to tackle this limitation inherent to the current visual servoing techniques. Our proposal is based on the coded structured light approach as a reliable and fast way to solve the correspondence problem. In this case, a coded light pattern is projected providing robust visual features independently of the object appearance.
2006_icra_pages.pdf (746.87 Ko) Télécharger le fichier
inria-00350317 , version 1 (06-01-2009)
  • HAL Id : inria-00350317 , version 1
J. Pagès, Christophe Collewet, François Chaumette, J. Salvi. An approach to visual servoing based on coded light. IEEE Int. Conf. on Robotics and Automation, ICRA'2006, 2006, Orlando, Florida, United States. pp.4118-4123. ⟨inria-00350317⟩
177 Consultations
120 Téléchargements
