Controlling an uninstrumented ROV manipulator by visual servoing. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
In this paper we present a vision-based method to control the displacement of robot arm mounted on an underwater ROV. A closed-loop system based on an eye-to-hand visual servoing approach has been designed to achieve this task. We show that, using such an approach, measuring the manipulator motion with proprioceptive sensors is not required to precisely control the end-effector motion. To maintain the end effector in the field of view, the camera orientation is also controlled. Presented results show the validity of the approach.
Mots clés
2001_ocean_marchand.pdf (471.03 Ko) Télécharger le fichier
inria-00352134 , version 1 (12-01-2009)
  • HAL Id : inria-00352134 , version 1
E. Marchand, François Chaumette, F. Spindler, M. Perrier. Controlling an uninstrumented ROV manipulator by visual servoing.. MTS/IEEE OCEANS 2001 Conference, 2001, Honolulu, Hawaii, United States. pp.1047-1053. ⟨inria-00352134⟩
188 Consultations
186 Téléchargements
