Simulating diffusions with piecewise constant coefficients using a kinetic approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2009
Using a kinetic approximation of a linear diffusion operator, we propose an algorithm that allows one to deal with the simulation of a multi-dimensional stochastic process in a media which is locally isotropic except on some surface where the diffusion coefficient presents some discontinuities. Numerical examples are given in dimensions one to three on PDEs or stochastic PDEs with or without source terms.
lejay-maire-2007-kinetic-approximation.pdf (181.48 Ko) Télécharger le fichier
inria-00358003 , version 1 (02-02-2009)
inria-00358003 , version 2 (02-10-2009)
inria-00358003 , version 3 (10-03-2010)
inria-00358003 , version 4 (23-03-2010)
  • HAL Id : inria-00358003 , version 1
Antoine Lejay, Sylvain Maire. Simulating diffusions with piecewise constant coefficients using a kinetic approximation. Computer Methods in Applied Mechanics and Engineering, 2009. ⟨inria-00358003v1⟩
230 Consultations
847 Téléchargements
