Locally Decodable Quantum Codes
We study a quantum analogue of locally decodable error-correcting codes. A q-query local ly decodable quantum code encodes n classical bits in an m-qubit state, in such a way that each of the encoded bits can be recovered with high probability by a measurement on at most q qubits of the quantum code, even if a constant fraction of its qubits have been corrupted adversarially. We show that such a quantum code can be transformed into a classical q-query locally decodable code of the same length that can be decoded well on average (albeit with smaller success probability and noise-tolerance). This shows, roughly speaking, that q-query quantum codes are not significantly better than q-query classical codes, at least for constant or small q.
