Strong Completeness of Coalgebraic Modal Logics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Dirk Pattinson
  • Fonction : Auteur
  • PersonId : 857983
Canonical models are of central importance in modal logic, in particular as they witness strong completeness and hence compactness. While the canonical model construction is well understood for Kripke semantics, non-normal modal logics often present subtle difficulties - up to the point that canonical models may fail to exist, as is the case e.g. in most probabilistic logics. Here, we present a generic canonical model construction in the semantic framework of coalgebraic modal logic, which pinpoints coherence conditions between syntax and semantics of modal logics that guarantee strong completeness. We apply this method to reconstruct canonical model theorems that are either known or folklore, and moreover instantiate our method to obtain new strong completeness results. In particular, we prove strong completeness of graded modal logic with finite multiplicities, and of the modal logic of exact probabilities.
schroder_new.pdf (174.54 Ko) Télécharger le fichier
inria-00360132 , version 1 (10-02-2009)
  • HAL Id : inria-00360132 , version 1
  • ARXIV : 0902.2072
Lutz Schröder, Dirk Pattinson. Strong Completeness of Coalgebraic Modal Logics. 26th International Symposium on Theoretical Aspects of Computer Science - STACS 2009, Feb 2009, Freiburg, Germany. pp.673-684. ⟨inria-00360132⟩
Collections
STACS2009
28 Consultations
190 Téléchargements
