A formally verified compiler back-end - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
This article describes the development and formal verification (proof of semantic preservation) of a compiler back-end from Cminor (a simple imperative intermediate language) to PowerPC assembly code, using the Coq proof assistant both for programming the compiler and for proving its correctness. Such a verified compiler is useful in the context of formal methods applied to the certification of critical software: the verification of the compiler guarantees that the safety properties proved on the source code hold for the executable compiled code as well.
paper.pdf (700.38 Ko) Télécharger le fichier
inria-00360768 , version 1 (11-02-2009)
inria-00360768 , version 2 (21-07-2009)
inria-00360768 , version 3 (14-11-2009)
  • HAL Id : inria-00360768 , version 1
  • ARXIV : 0902.2137
Xavier Leroy. A formally verified compiler back-end. 2009. ⟨inria-00360768v1⟩
479 Consultations
826 Téléchargements
