New interface
Reports (Research report)
Stability of a local greedy distributed routing algorithm
Florian Huc 1 Christelle Molle 2, * Nicolas Nisse 2 Stéphane Pérennes 2 Hervé Rivano 2
* Corresponding author
2 MASCOTTE - Algorithms, simulation, combinatorics and optimization for telecommunications
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : In this work, we study the problem of routing packets between undifferentiated sources and sinks in a network modeled by a multigraph. We provide a distributed and local algorithm that transmits packets hop by hop in the network and study its behaviour. At each step, a node transmits its queued packets to its neighbours in order to optimize a local gradient. This protocol is thus greedy since it does not require to record the history about the past actions, and lazy since it only needs informations of the neighborhood. We prove that this protocol is stable in the sense that the number of packets stored in the network stays bounded as soon as the sources injects a flow that another method could have exhausted. In particular, our protocol stays stable even if the feasibility condition is not strict on topologies with several sources and destinations, under a conjecture when the value of the flow is constrained at the destination nodes. We therefore reinforce a result from the literature that worked for differentiated suboptimal flows.
Document type :
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/inria-00366441
Contributor : Christelle Caillouet Connect in order to contact the contributor
Submitted on : Tuesday, October 6, 2009 - 3:56:35 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:42 AM
Long-term archiving on: : Wednesday, September 22, 2010 - 1:27:19 PM
File
RR-6871.pdf
Identifiers
  • HAL Id : inria-00366441, version 2
Citation
Florian Huc, Christelle Molle, Nicolas Nisse, Stéphane Pérennes, Hervé Rivano. Stability of a local greedy distributed routing algorithm. [Research Report] RR-6871, INRIA. 2009. ⟨inria-00366441v2⟩
Share
Metrics
Record views
167
Files downloads
137
