A LPV approach to control and real-time scheduling codesign: application to a robot-arm control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Olivier Sename
Daniel Simon
Mohamed El Mongi Ben Gaïd
  • Fonction : Auteur
  • PersonId : 848125
This paper deals with real-time control under computational constraints. A robust control approach to control/real-time scheduling co-design is proposed using the $H_\infty$ framework for Linear Parameter Varying (LPV) polytopic systems. The originality consists in a new resource sharing between control tasks according to the controlled plant performances. Here the varying parameters are images of the control performance w.r.t. the sampling frequencies. Then a LPV based feedback scheduler is designed to adapt the control tasks periods according to the plant behavior and to the availability of computing resources. The approach is illustrated with a robot-arm controller design, whose feasibility is assessed in simulation.
Automatique
cdc08-450.pdf (785.07 Ko) Télécharger le fichier
inria-00367679 , version 1 (12-03-2009)
  • HAL Id : inria-00367679 , version 1
Olivier Sename, Daniel Simon, Mohamed El Mongi Ben Gaïd. A LPV approach to control and real-time scheduling codesign: application to a robot-arm control. CDC 2008 - 47th IEEE Conference on Decision and Control, IEEE, Dec 2008, Cancun, Mexico. ⟨inria-00367679⟩
302 Consultations
328 Téléchargements
