Structured Sparsity: from Mixed Norms to Structured Shrinkage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Sparse and structured signal expansions on dictionaries can be obtained through explicit modeling in the coefficient domain. The originality of the present contribution lies in the construction and the study of generalized shrinkage operators, whose goal is to identify structured significance maps. These generalize Group LASSO and the previously introduced Elitist LASSO by introducing more flexibility in the coefficient domain modeling. We study experimentally the performances of corresponding shrinkage operators in terms of significance map estimation in the orthogonal basis case. We also study their performance in the overcomplete situation, using iterative thresholding.
30.pdf (230.47 Ko) Télécharger le fichier
inria-00369577 , version 1 (20-03-2009)
  • HAL Id : inria-00369577 , version 1
Matthieu Kowalski, Bruno Torrésani. Structured Sparsity: from Mixed Norms to Structured Shrinkage. SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations, Inria Rennes - Bretagne Atlantique, Apr 2009, Saint Malo, France. ⟨inria-00369577⟩
455 Consultations
812 Téléchargements
