Dealing with AADL end-to-end Flow Latency with UML Marte. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
AADL and MARTE are both modeling formalisms supporting the analysis of real-time embedded systems. We investigate how MARTE, with its Time Model facilities, can be made to represent faithfully AADL periodic/aperiodic tasks communicating through event or data ports, in an approach to end-to-end flow latency analysis.
uml_aadl08.pdf (249.52 Ko) Télécharger le fichier
inria-00371400 , version 1 (27-03-2009)
Su-Young Lee, Frédéric Mallet, Robert de Simone. Dealing with AADL end-to-end Flow Latency with UML Marte.. ICECCS - UML&AADL, Apr 2008, Belfast, Ireland. pp.228-233, ⟨10.1109/ICECCS.2008.14⟩. ⟨inria-00371400⟩
117 Consultations
173 Téléchargements
