DynaSpot: Speed-Dependent Area Cursor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present DynaSpot, a new technique for acquiring targets based on the area cursor. DynaSpot couples the cursor's activation area with its speed, behaving like a point cursor at low speed or when motionless. This technique minimizes visual distraction and allows pointing anywhere in empty space without requiring an explicit mode switch, thus enabling users to perform common interactions such as region selections seamlessly. The results of our controlled experiments show that the performance of DynaSpot can be modeled by Fitts' law, and that DynaSpot significantly outperforms the point cursor and achieves, in most conditions, the same level of performance as one of the most promising techniques to date, the Bubble cursor.
chi2009_dynaspot.pdf (455.98 Ko) Télécharger le fichier
chi2009_dynaspot.mov (27.06 Mo) Télécharger le fichier
Format : Figure, Image
inria-00373678 , version 1 (06-04-2009)
Olivier Chapuis, Jean-Baptiste Labrune, Emmanuel Pietriga. DynaSpot: Speed-Dependent Area Cursor. CHI '09: SIGCHI conference on Human Factors in computing systems, ACM, Apr 2009, Boston, United States. pp.1391--1400, ⟨10.1145/1518701.1518911⟩. ⟨inria-00373678⟩
717 Consultations
771 Téléchargements
