Distributed Processing of Continous Join Queries using DHT Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
This paper addresses the problem of computing approximate answers to continuous join queries. We present a new method, called DHTJoin, which combines hash-based placement of tuples in a Distributed Hash Table (DHT) and dissemination of queries exploiting the trees formed by the underlying DHT links. DHTJoin distributes the query workload across multiple DHT nodes and provides a mechanism that avoids indexing tuples that cannot contribute to join results. We provide a performance evaluation which shows that DHTJoin can achieve significant performance gains in terms of network traffic.
DHTJoinCompleteness-INRIA.pdf (294.26 Ko) Télécharger le fichier
inria-00375277 , version 1 (14-04-2009)
inria-00375277 , version 2 (21-08-2009)
  • HAL Id : inria-00375277 , version 1
Wenceslao Palma, Esther Pacitti, Reza Akbarinia, Patrick Valduriez. Distributed Processing of Continous Join Queries using DHT Networks. 2009. ⟨inria-00375277v1⟩
Collections
LINA-GDD
211 Consultations
89 Téléchargements
