Benchmarking the BFGS Algorithm on the BBOB-2009 Noisy Testbed
The BFGS quasi-Newton method is benchmarked on the noisy BBOB-2009 testbed. A multistart strategy is applied with a maximum number of function evaluations of about 10^4 times the search space dimension.
Analyse numérique [cs.NA]
