Using Bypass to Tighten WCET Estimates for Multi-Core Processors with Shared Instruction Caches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Damien Hardy
Thomas Piquet
  • Fonction : Auteur
  • PersonId : 836828
Isabelle Puaut
Multi-core chips have been increasingly adopted by the microprocessor industry. For real-time systems to exploit multi-core architectures, it is required to obtain both tight and safe estimates of worst-case execution times (WCETs). Estimating WCETs for multi-core platforms is very challenging because of the possible interferences between cores due to shared hardware resources such as shared caches, memory bus, etc. This paper proposes a compile-time approach to reduce shared instruction cache interferences between cores to tighten WCET estimations. Unlike [J. Yan and W. Zhang 08], which accounts for all possible conflicts caused by tasks running on the other cores when estimating the WCET of a task, our approach drastically reduces the amount of inter-core interferences. This is done by controlling the contents of the shared instruction cache(s), by caching only blocks statically known as reused. Experimental results demonstrate the practicality of our approach.
RR-6907.pdf (241.25 Ko) Télécharger le fichier
inria-00380298 , version 1 (30-04-2009)
  • HAL Id : inria-00380298 , version 1
Damien Hardy, Thomas Piquet, Isabelle Puaut. Using Bypass to Tighten WCET Estimates for Multi-Core Processors with Shared Instruction Caches. [Research Report] RR-6907, INRIA. 2009. ⟨inria-00380298⟩
255 Consultations
430 Téléchargements
