Towards Performance Prediction of Compositional Models in Industrial GALS Designs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Systems and Networks on Chips (NoCs) are a prime design focus of many hardware manufacturers. In addition to functional verification, which is a difficult necessity, the chip designers are facing extremely demanding performance prediction challenges, such as the need to estimate the latency of memory accesses over the NoC. This paper attacks this problem in the setting of designing globally asynchronous, locally synchronous systems (GALS). We describe foundations and applications of a combination of compositional modeling, model checking, and Markov process theory, to arrive at a viable approach to compute performance quantities directly on industrial, functionally verified GALS models.
final_version.pdf (315.92 Ko) Télécharger le fichier
inria-00381657 , version 1 (06-05-2009)
  • HAL Id : inria-00381657 , version 1
Nicolas Coste, Holger Hermanns, Etienne Lantreibecq, Wendelin Serwe. Towards Performance Prediction of Compositional Models in Industrial GALS Designs. Computer Aided Verification, Saddek Bensalem, 2009, Grenoble, France. ⟨inria-00381657⟩
128 Consultations
145 Téléchargements
