Marte CCSL to execute East-ADL Timing Requirements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In the automotive domain, several loosely-coupled Architecture Description Languages (ADLs) compete to provide a set of abstract modeling and analysis services on top of the implementation code. In an effort to make all these languages, and more importantly their underlying models, interoperable, we use the UML Profile for MARTE as a pivot to define the semantics of these models. In this paper, we particularly focus on East-ADL2. We discuss the benefits of having an integrated, MARTE-centered, approach. We give a formal semantics of East-ADL2 timing requirements. Relying on this semantics, several kinds of analysis are possible. Requirements become executable and simulations are run. A constraint solver is used to detect logical inconsistencies. Our proposal is illustrated on an Anti-lock Braking System (ABS).
EastMarte.pdf (148.24 Ko) Télécharger le fichier
inria-00383262 , version 1 (12-05-2009)
Frédéric Mallet, Marie-Agnès Peraldi-Frati, Charles André. Marte CCSL to execute East-ADL Timing Requirements. Int. Symp. on Object/component/service-oriented Real-time distributed Computing (ISORC'09), Mar 2009, Tokyo, Japan. pp.249-253, ⟨10.1109/ISORC.2009.18⟩. ⟨inria-00383262⟩
308 Consultations
359 Téléchargements
