A New 3D Lip Model for Analysis and Synthesis of Lip Motion in Speech Production - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
This work presents a methodology for 3D modeling of lip motion in speech production and its application to lip tracking and visual speech animation. Firstly, a geometric modeling allows to create a 3D lip model from 30 control points for any lip shape. Secondly, a statistical analysis, performed on a set of 10 key shapes, generates a lip gesture coding with three articulatory-oriented parameters, specific to one speaker. The choice of the key shapes is based on general phonetic observations. Finally, the application for lip tracking of the 3D model controlled by the three parameters is presented and evaluated.
avsp98.pdf (1.51 Mo) Télécharger le fichier
Format : Figure, Image
inria-00389368 , version 1 (28-05-2009)
  • HAL Id : inria-00389368 , version 1
Lionel Reveret, Christian Benoit. A New 3D Lip Model for Analysis and Synthesis of Lip Motion in Speech Production. ESCA Workshop on Audio-Visual Speech Processing, AVSP'98, Dec 1998, Terrigal, Australia. ⟨inria-00389368⟩
516 Consultations
823 Téléchargements
