Lasalle's Invariance Theorem for Nonsmooth Lagrangian Dynamical Systems - Archive ouverte HAL Access content directly
Conference Papers Year : 2005
A key condition for the statement of Lasalle's invariance theorem is the continuity of the trajectories of the dynamical systems with respect to initial conditions. Systems with discontinuous flows generally don't present such a continuity, but in the particular case of nonsmooth Lagrangian dynamical systems we will see that in fact this continuity property holds in most cases. We will then be able to propose a a LaSalle's invariance theorem for nonsmooth dynamical systems satisfying this property through the use of general time-invariant flows.orem for nonsmooth dynamical systems still needs to be stated, so we propose here to extend this theorem through the framework of nonsmooth dynamical systems.
lasalle.pdf (104.37 Ko) Télécharger le fichier
Dates and versions
inria-00390416 , version 1 (02-06-2009)
Identifiers
  • HAL Id : inria-00390416 , version 1
Cite
Sophie Chareyron, Pierre-Brice Wieber. Lasalle's Invariance Theorem for Nonsmooth Lagrangian Dynamical Systems. Euromech Nonlinear Dynamics Conference, 2005, Eindhoven, Netherlands. ⟨inria-00390416⟩
155 View
474 Download
Share
