New interface
Conference papers
Stabilization of time-delay systems through linear differential equations using a descriptor representation
Alexandre Seuret 1 Karl Henrik Johansson 2
1 NECS - Networked Controlled Systems
Inria Grenoble - Rhône-Alpes, GIPSA-DA - Département Automatique
Abstract : In this article, a new method to assess stability and to design static state feedback controller for linear timedelay systems is introduced. The method based on linear differential equations allows considering explicit Lyapunov-Krasovskii functionals with non constant matrix parameters. The stability conditions considering constant delays are delaydependent and expressed using easy computable linear matrix inequalities. An example is introduced to show the efficiency of the stabilization criteria.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/inria-00391311
Contributor : Alexandre Seuret Connect in order to contact the contributor
Submitted on : Wednesday, June 3, 2009 - 5:11:15 PM
Last modification on : Thursday, January 20, 2022 - 5:29:17 PM
Long-term archiving on: : Monday, October 15, 2012 - 11:45:43 AM
File
ECC_NewLKF2.pdf
Identifiers
  • HAL Id : inria-00391311, version 1
Collections
Citation
Alexandre Seuret, Karl Henrik Johansson. Stabilization of time-delay systems through linear differential equations using a descriptor representation. ECC 2009 - European Control Conference, Aug 2009, Budapest, Hungary. ⟨inria-00391311⟩
Share
Metrics
Record views
157
Files downloads
177
