An observation algorithm for nonlinear systems with unknown inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2009
This paper provides some new developments in the design of unknown input observers for nonlinear systems. An algorithm which states if the state and the unknown input of the system can be recovered in finite time is introduced. This algorithm leads to the transformation of the system into an extended block triangular observable form suitable for the design of finite time observers. The proposed method is useful to relax some restrictive conditions of existing nonlinear unknown input observer design procedures.
Automatique
ObsNL_Hal.pdf (140.69 Ko) Télécharger le fichier
inria-00391819 , version 1 (04-06-2009)
Jean-Pierre Barbot, Driss Boutat, Thierry Floquet. An observation algorithm for nonlinear systems with unknown inputs. Automatica, 2009, 45 (8), pp.1970-1974. ⟨10.1016/j.automatica.2009.04.009⟩. ⟨inria-00391819⟩
288 Consultations
494 Téléchargements
