Abstract : This paper presents a simple proof that the quorum failure detector class (denoted ) is the weakest failure detector class required to implement an atomic read/write register in an asynchronous message-passing system prone to an arbitrary number of process crashes.
https://hal.inria.fr/inria-00392450 Contributor : Anne JaiguConnect in order to contact the contributor Submitted on : Monday, June 8, 2009 - 10:31:09 AM Last modification on : Thursday, January 20, 2022 - 4:20:09 PM Long-term archiving on: : Thursday, June 10, 2010 - 8:48:00 PM
François Bonnet, Michel Raynal. A simple proof of the necessity of the failure detector $\Sigma$ to implement a register in asynchronous message-passing systems. [Research Report] PI 1932, 2009, pp.8. ⟨inria-00392450⟩
