A simple proof of the necessity of the failure detector $\Sigma$ to implement a register in asynchronous message-passing systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
This paper presents a simple proof that the quorum failure detector class (denoted ) is the weakest failure detector class required to implement an atomic read/write register in an asynchronous message-passing system prone to an arbitrary number of process crashes.
PI-1932.pdf (371.41 Ko) Télécharger le fichier
inria-00392450 , version 1 (08-06-2009)
  • HAL Id : inria-00392450 , version 1
François Bonnet, Michel Raynal. A simple proof of the necessity of the failure detector $\Sigma$ to implement a register in asynchronous message-passing systems. [Research Report] PI 1932, 2009, pp.8. ⟨inria-00392450⟩
237 Consultations
243 Téléchargements
