CONNECT Challenges: Towards Emergent Connectors for Eternal Networked Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The CONNECT European project that started in February 2009 aims at dropping the interoperability barrier faced by today's distributed systems. It does so by adopting a revolutionary approach to the seamless networking of digital systems, that is, synthesizing on the fly the connectors via which networked systems communicate. CONNECT investigates formal foundations for connectors together with associated automated support for learning, reasoning about and adapting the interaction behavior of networked systems.
Connect_challenges.pdf (196.53 Ko) Télécharger le fichier
inria-00392809 , version 1 (09-06-2009)
Valérie Issarny, Bernhard Steffen, Bengt Jonsson, Gordon Blair, Paul Grace, et al.. CONNECT Challenges: Towards Emergent Connectors for Eternal Networked Systems. 14th IEEE International Conference on Engineering of Complex Computer Systems, Jun 2009, Postdam, Germany. pp.154-161, ⟨10.1109/ICECCS.2009.44⟩. ⟨inria-00392809⟩
185 Consultations
507 Téléchargements
