A contextual dissimilarity measure for accurate and efficient image search - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2007
Hervé Jégou
  • Function : Author
  • PersonId : 833473
Harzallah Hedi
  • Function : Author
  • PersonId : 861132
Cordelia Schmid
  • Function : Author
  • PersonId : 831154
In this paper we present two contributions to improve accuracy and speed of an image search system based on bag-of-features: a contextual dissimilarity measure (CDM) and an efficient search structure for visual word vectors. Our measure (CDM) takes into account the local distribution of the vectors and iteratively estimates distance correcting terms. These terms are subsequently used to update an existing distance, thereby modifying the neighborhood structure. Experimental results on the Nister-Stewenius dataset show that our approach significantly outperforms the state-of-the-art in terms of accuracy. Our efficient search structure for visual word vectors is a two-level scheme using inverted files. The first level partitions the image set into clusters of images. At query time, only a subset of clusters of the second level has to be searched. This method allows fast querying in large sets of images. We valuate the gain in speed and the loss in accuracy on large datasets (up to 1 million images).
jegou_cdm.pdf (3.5 Mo) Télécharger le fichier
cvpr2007_talk.pdf (3.19 Mo) Télécharger le fichier
Format : Figure, Image
Format : Other
Dates and versions
inria-00394210 , version 1 (15-03-2011)
Identifiers
Cite
Hervé Jégou, Harzallah Hedi, Cordelia Schmid. A contextual dissimilarity measure for accurate and efficient image search. CVPR 2007 - Conference on Computer Vision & Pattern Recognition, Jun 2007, Minneapolis, United States. pp.1-8, ⟨10.1109/CVPR.2007.382970⟩. ⟨inria-00394210⟩
291 View
654 Download
Share
