Blind deconvolution for thin layered confocal imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied optics Année : 2009
Praveen Pankajakshan
  • Fonction : Auteur
  • PersonId : 848130
Bo Zhang
  • Fonction : Auteur
  • PersonId : 861226
Zvi Kam
  • Fonction : Auteur
  • PersonId : 861227
Jean-Christophe Olivo-Marin
  • Fonction : Auteur
  • PersonId : 861228
Josiane Zerubia
  • Fonction : Auteur
  • PersonId : 833424
In this paper, we have proposed an Alternate Minimization (AM) algorithm for estimating the Point-Spread Function (PSF) of a Confocal Laser Scanning Microscope (CLSM) and the specimen fluorescence distribution. A 3-D separable Gaussian model is used to restrict the PSF solution space and a constraint on the specimen is used so as to favor the stabilization and convergence of the algorithm. The results obtained from the simulation show that the PSF can be estimated to a high degree of accuracy, and those on real data show better deconvolution as compared to a full theoretical PSF model.
AppliedOpticsPaperTypesetting.pdf (1016.93 Ko) Télécharger le fichier
inria-00395523 , version 1 (15-06-2009)
Praveen Pankajakshan, Bo Zhang, Laure Blanc-Féraud, Zvi Kam, Jean-Christophe Olivo-Marin, et al.. Blind deconvolution for thin layered confocal imaging. Applied optics, 2009, 48 (22), ⟨10.1364/AO.48.004437⟩. ⟨inria-00395523⟩
224 Consultations
366 Téléchargements
