Geo-temporal structuring of a personal image database with two-level variational-Bayes mixture estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses unsupervised hierarchical classication of personal documents tagged with time and geolocation stamps. The target application is browsing among these documents. A rst partition of the data is built, based on geo-temporal measurement. The events found are then grouped according to geolocation. This is carried out through tting a two-level hierarchy of mixture models to the data. Both mixtures are estimated in a Bayesian setting, with a variational proce- dure: the classical VBEM algorithm is applied for the ner level, while a new variational-Bayes-EM algorithm is introduced to search for suitable groups of mixture components from the ner level. Experimental results are reported on articial and real data.
amr.pdf (140.4 Ko) Télécharger le fichier
inria-00396790 , version 1 (18-06-2009)
  • HAL Id : inria-00396790 , version 1
Pierrick Bruneau, Antoine Pigeau, Marc Gelgon, Fabien Picarougne. Geo-temporal structuring of a personal image database with two-level variational-Bayes mixture estimation. Adaptive Multimedia Retrieval workshop (AMR'08), HHI Berlin, Jun 2008, Berlin, Germany. pp.127-139. ⟨inria-00396790⟩
164 Consultations
221 Téléchargements
