Ana4: a 2.5 Framework for Deploying Real Multi-hop Ad hoc and Mesh Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ad Hoc & Sensor Wireless Networks Année : 2006
We consider the problem of interconnecting several hosts in a spontaneous hybrid and heterogeneous network, i.e. an environment where wired and multi-hop wireless technologies are used. Dealing with issues raised by such hybrid networks and addressing all challenges listed in MANet may require a departure from classical solutions available in the literature. To enable a full multi-hop connectivity without raising problems/inconsistencies regarding IP compatibility, we propose Ana4 (a.k.a.Ananas), a 2.5 layer architecture suitable for hybrid heterogeneous networks. In this article, we present the architecture and implementations of Ana4 in the context of ad hoc and mesh networks as well as application fields where Ana4 is already used. We also present experimental measurements that show good performances with respect to a full IP solution (IP routing) and similar 2.5 approaches like MPLS.
Fichier non déposé
inria-00397040 , version 1 (19-06-2009)
  • HAL Id : inria-00397040 , version 1
Nicolas Boulicault, Guillaume Chelius, Eric Fleury. Ana4: a 2.5 Framework for Deploying Real Multi-hop Ad hoc and Mesh Networks. Ad Hoc & Sensor Wireless Networks, 2006, 2 (4). ⟨inria-00397040⟩
202 Consultations
0 Téléchargements
