Convergence of U-statistics for interacting particle systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The convergence of U-statistics has been intensively studied for estimators based on families of i.i.d. random variables and variants of them. In most cases, the independence assumption is crucial. When dealing with Feynman-Kac and other interacting particle systems of Monte Carlo type, one faces a new type of problem. Namely, in a sample of N particles obtained through the corresponding algorithms, the distributions of the particles are correlated -although any finite number of them is asymptotically independent with respect to the total number N of particles. In the present article, exploiting the fine asymptotics of particle systems, we prove convergence theorems for U-statistics in this framework.
RR-6966.pdf (291.68 Ko) Télécharger le fichier
inria-00397366 , version 1 (21-06-2009)
  • HAL Id : inria-00397366 , version 1
Pierre del Moral, Frédéric Patras, Sylvain Rubenthaler. Convergence of U-statistics for interacting particle systems. [Research Report] RR-6966, INRIA. 2009, pp.20. ⟨inria-00397366⟩
357 Consultations
192 Téléchargements
