NEPI: Using Independent Simulators, Emulators, and Testbeds for Easy Experimentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Mathieu Lacage
  • Fonction : Auteur
  • PersonId : 833489
Martin Ferrari
  • Fonction : Auteur
  • PersonId : 861349
Mads Hansen
  • Fonction : Auteur
  • PersonId : 861350
Walid Dabbous
The evaluation of new network protocols, applications, and architectures, requires the use of many kinds of experimentation environments: simulators, emulators, testbeds, and sometimes, combinations of these. As the functionality and complexity of these tools increases, mastering and efficiently using each of them is becoming increasingly difficult. In this paper, we consider how to make it easier to use multiple tools separately and together to improve the productivity of network researchers. We show how a single object model which encompasses every aspect of a typical experimentation workflow can be used to completely describe experiments to be run within very different experimentation environments. Although Nepi is still in early prototyping stage, we expect that its ability to describe and automate easily complex mixed experiments will enable further experimentation with heterogenous networks.
RR-6967.pdf (533.97 Ko) Télécharger le fichier
inria-00397692 , version 1 (23-06-2009)
  • HAL Id : inria-00397692 , version 1
Mathieu Lacage, Martin Ferrari, Mads Hansen, Thierry Turletti, Walid Dabbous. NEPI: Using Independent Simulators, Emulators, and Testbeds for Easy Experimentation. [Research Report] RR-6967, INRIA. 2009. ⟨inria-00397692⟩
112 Consultations
100 Téléchargements
