CRDTs: Consistency without concurrency control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
A CRDT is a data type whose operations commute when they are concurrent. Replicas of a CRDT eventually converge without any complex concurrency control. As an existence proof, we exhibit a non-trivial CRDT: a shared edit buffer called Treedoc. We outline the design, implementation and performance of Treedoc. We discuss how the CRDT concept can be generalised, and its limitations.
RR-6956.pdf (201.79 Ko) Télécharger le fichier
inria-00397981 , version 1 (06-07-2009)
  • HAL Id : inria-00397981 , version 1
  • ARXIV : 0907.0929
Mihai Leția, Nuno Preguiça, Marc Shapiro. CRDTs: Consistency without concurrency control. [Research Report] RR-6956, INRIA. 2009, pp.16. ⟨inria-00397981⟩
1688 Consultations
5822 Téléchargements
