Probabilistic motion planning among moving obstacles following typical motion patterns. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The paper presents a navigation algorithm for dynamic, uncertain environment. The static environment is unknown, while moving pedestrians are detected and tracked on-line. Pedestrians are supposed to move along typical motion patterns represented by HMMs. The planning algorithm is based on an extension of the Rapidly-exploring Random Tree algorithm, where the likelihood of the obstacles future trajectory and the probability of collision is explicitly taken into account. The algorithm is used in a partial motion planner, and the probability of collision is updated in real-time according to the most recent estimation. Results show the performance for a car-like robot in a simulated environment among multiple dynamic obstacles.
main.pdf (831.15 Ko) Télécharger le fichier
inria-00398059 , version 1 (24-06-2009)
  • HAL Id : inria-00398059 , version 1
Chiara Fulgenzi, Anne Spalanzani, Christian Laugier. Probabilistic motion planning among moving obstacles following typical motion patterns.. IEEE/RSJ International Conference on Intelligent RObots and Systems, Oct 2009, St. Louis, Missouri, United States. ⟨inria-00398059⟩
246 Consultations
5625 Téléchargements
