Swirling-Sweepers: Constant Volume Modeling
Swirling-sweepers is a new method formodeling shapes while preserving volume. The artist describes a deformation by dragging a point along a path. The method is independent of the geometric representation of the shape. It preserves volume and avoids self-intersections, both local and global. It is capable of unlimited stretching and the deformation can be constrained to affect only a part of the model. We argue that all of these properties are necessary for interactive modeling if the user is to have the impression that he or she is shaping a real material. Our method is the first to implement all five.
ACWK04.pdf (338.37 Ko)
Télécharger le fichier
Format : Figure, Image
