A Hybrid Linear Logic for Constrained Transition Systems with Applications to Molecular Biology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Linear implication can represent state transitions, but real transition systems operate under temporal, stochastic or probabilistic constraints that are not directly representable in ordinary linear logic. We propose a general modal extension of intuitionistic linear logic where logical truth is indexed by constraints and hybrid connectives combine constraint reasoning with logical reasoning. The logic has a focused cut-free sequent calculus that can be used to internalize the rules of particular constrained transition systems; we illustrate this with an adequate encoding of the synchronous stochastic pi-calculus.
hyll_report.pdf (234.77 Ko) Télécharger le fichier
inria-00402942 , version 1 (01-10-2009)
inria-00402942 , version 2 (01-10-2009)
inria-00402942 , version 3 (21-10-2009)
inria-00402942 , version 4 (10-12-2010)
inria-00402942 , version 5 (16-10-2013)
  • HAL Id : inria-00402942 , version 1
Kaustuv C. Chaudhuri, Joelle Despeyroux. A Hybrid Linear Logic for Constrained Transition Systems with Applications to Molecular Biology. [Research Report] 2009. ⟨inria-00402942v1⟩
425 Consultations
370 Téléchargements
