Article Dans Une Revue Communications in Computational Physics Année : 2010
Analytical solution for waves propagation in heterogeneous acoustic/porous media. Part I: the 2D case
Thanks to the Cagniard-de Hoop we derive the solution to the problem of wave propagation in an infinite bilayered acoustic/poroelastic media, where the poroelastic layer is modelled by the biphasic Biot's model. This first part is dedicated to solution to the two dimensional problem. We illustrate the interest of the solution by using it to validate a numerical code.
inria-00404224 , version 1 (15-07-2009)
Julien Diaz, Abdelaâziz Ezziani. Analytical solution for waves propagation in heterogeneous acoustic/porous media. Part I: the 2D case. Communications in Computational Physics, 2010, 7 (1), pp.171-194. ⟨10.4208/cicp.2009.08.148⟩. ⟨inria-00404224⟩
218 Consultations
0 Téléchargements
More
