Towards a Formalization of Mediating Connectors for on the Fly Interoperability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Romina Spalazzese
  • Fonction : Auteur
  • PersonId : 861945
Paola Inverardi
  • Fonction : Auteur
  • PersonId : 861067
Mediators stand as a core architectural paradigm for today's and future systems that increasingly need to be connected. The mediator concept has been used to cope with many heterogeneity dimensions. Still, a key challenge for today's systems architectures is to embed the necessary support for automated mediation, i.e., the connector concept needs to evolve towards the one of mediating connector. In this paper, we introduce a framework to formalize mediating connectors. The proposed characterization paves the way for automated reasoning about protocol matching and mapping, and thus for the dynamic synthesis of mediating connectors to enable eternal networked systems, which we investigate as part of the CONNECT European project
SII_wicsaecsa09_cr.pdf (112.8 Ko) Télécharger le fichier
inria-00404308 , version 1 (16-07-2009)
  • HAL Id : inria-00404308 , version 1
Romina Spalazzese, Paola Inverardi, Valérie Issarny. Towards a Formalization of Mediating Connectors for on the Fly Interoperability. Joint Working IEEE/IFIP Conference on Software Architecture 2009 & European Conference on Software Architecture 2009, Sep 2009, Cambridge, United Kingdom. ⟨inria-00404308⟩
132 Consultations
177 Téléchargements
