jYang : A YANG parser in java - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Technical Report) Year : 2009
The NETCONF configuration protocol of the IETF Network Work- ing Group provides mechanisms to manipulate the configuration of network devices. YANG is the language currently under consideration within the IETF to specify the data models to be used in NETCONF . This report describes the design and development of a syntax and semantics parser for YANG in java.
Keywords
yang.pdf (266.2 Ko) Télécharger le fichier
Dates and versions
inria-00411261 , version 1 (27-08-2009)
Identifiers
  • HAL Id : inria-00411261 , version 1
  • ARXIV : 0908.4005
Cite
Emmanuel Nataf, Olivier Festor. jYang : A YANG parser in java. [Technical Report] 2009, pp.29. ⟨inria-00411261⟩
174 View
1927 Download
Share
