Low Power Multistandard Simultaneous Reception Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we address the architecture of multistandard simultaneous reception receivers and we aim at improving both the complexity and the power consumption of the analog front-end. To this end we propose an architecture using the double orthogonal translation technique in order to multiplex two received signals. A study case concerning the simultaneous reception of 802.11g and UMTS signals is developed in this article.
23.pdf (94.46 Ko) Télécharger le fichier
inria-00412028 , version 1 (27-11-2009)
  • HAL Id : inria-00412028 , version 1
Ioan Burciu, Jacques Verdier, Guillaume Villemaud. Low Power Multistandard Simultaneous Reception Architecture. European Wireless Technology Conference 2009, Sep 2009, Rome, Italy. ⟨inria-00412028⟩
134 Consultations
75 Téléchargements
