Candidate Architecture for MIMO LTE-Advanced Receivers with Multiple Channels Capabilities and Reduced Complexity and Cost - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, a candidate architecture for LTEAdvanced receiver is proposed. Based on the combination of MIMO techniques and flexible spectrum access, LTE-Advanced terminals will require an increasing complexity of the front-end part. To reduce the complexity of the analog front-end, an innovative architecture is introduced based on the merging between the double IQ and code multiplexing structure. Simulation results show that, in a Gaussian case, the bit error rate does not increase significantly when using this architecture. A complexity evaluation study reveals significantly reduced power consumption when implementing the proposed single front-end architecture.
Burciu_COST_TD_09_844.pdf (215.92 Ko) Télécharger le fichier
inria-00412103 , version 1 (27-11-2009)
  • HAL Id : inria-00412103 , version 1
Ioan Burciu, Guillaume Villemaud, Jacques Verdier. Candidate Architecture for MIMO LTE-Advanced Receivers with Multiple Channels Capabilities and Reduced Complexity and Cost. COST2100 Pervasive Mobile & Ambient Wireless Communications, May 2009, Valence, Spain. ⟨inria-00412103⟩
221 Consultations
528 Téléchargements
