Discrete-time multi-scale systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
We introduce multi-scale filtering by the way of certain double convolution systems. We prove stability theorems for these systems and make connections with function theory in the poly-disc. Finally, we compare the framework developed here with the white noise space framework, within which a similar class of double convolution systems has been defined earlier.
scalefilter.pdf (279.48 Ko) Télécharger le fichier
inria-00421400 , version 1 (01-10-2009)
  • HAL Id : inria-00421400 , version 1
  • ARXIV : 0910.0234
Daniel Alpay, Mamadou Mboup. Discrete-time multi-scale systems. 2009. ⟨inria-00421400⟩
226 Consultations
227 Téléchargements
