Multiple Sclerosis lesion segmentation using an automatic multimodal Graph Cuts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Graph Cuts have been shown as a powerful interactive segmentation technique in several medical domains.We propose to automate the Graph Cuts in order to automatically segment Multiple Sclerosis (MS) lesions in MRI. We replace the manual interaction with a robust EM-based approach in order to discriminate between MS lesions and the Normal Appearing Brain Tissues (NABT). Evaluation is performed in synthetic and real images showing good agreement between the automatic segmentation and the target segmentation. We compare our algorithm with the state of the art techniques and with several manual segmentations. An advantage of our algorithm over previously published ones is the possibility to semi-automatically improve the segmentation due to the Graph Cuts interactive feature.
09-MICCAI-Graphcuts.pdf (137.15 Ko) Télécharger le fichier
inria-00423040 , version 1 (22-01-2010)
Daniel García-Lorenzo, Jérémy Lecoeur, Douglas L. Arnold, D. Louis Collins, Christian Barillot. Multiple Sclerosis lesion segmentation using an automatic multimodal Graph Cuts: Multiple Sclerosis lesion segmentation using an automatic multimodal Graph Cuts. 12th International Conference on Medical Image Computing and Computer Assisted Intervention, Sep 2009, Londres, United Kingdom. pp.584-591, ⟨10.1007/978-3-642-04271-3⟩. ⟨inria-00423040⟩
328 Consultations
539 Téléchargements
