New interface
Journal articles
Higher order Moreau's sweeping process: Mathematical formulation and numerical simulation
Vincent Acary 1 Bernard Brogliato 1 Daniel Goeleven 2
1 BIPOP - Modelling, Simulation, Control and Optimization of Non-Smooth Dynamical Systems
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : In this paper we present an extension of Moreau's sweeping process for higher order systems. The dynamical framework is carefully introduced, qualitative, dissipativity, stability, existence, regularity and uniqueness results are given. The time-discretization of these nonsmooth systems with a time-stepping algorithm is also presented. This differential inclusion can be seen as a mathematical formulation of complementarity dynamical systems with arbitrary dimension and arbitrary relative degree between the complementary-slackness variables. Applications of such high-order sweeping processes can be found in dynamic optimization under state constraints and electrical circuits with ideal diodes.
Document type :
Journal articles
Complete list of metadata
Cited literature [72 references]  Display  Hide  Download
https://hal.inria.fr/inria-00423566
Contributor : Vincent Acary Connect in order to contact the contributor
Submitted on : Sunday, October 29, 2017 - 4:23:45 PM
Last modification on : Monday, April 25, 2022 - 8:46:09 AM
Long-term archiving on: : Tuesday, January 30, 2018 - 12:17:10 PM
File
VABBDG.pdf
Identifiers
Citation
Vincent Acary, Bernard Brogliato, Daniel Goeleven. Higher order Moreau's sweeping process: Mathematical formulation and numerical simulation. Mathematical Programming, 2008, 113 (1), pp.133-217. ⟨10.1007/s10107-006-0041-0⟩. ⟨inria-00423566⟩
Share
Metrics
Record views
564
Files downloads
156
