Sequential decomposition of operations and compilers optimization - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2009
(1) , (1) , (2)
1
2
Code optimization is an important area of research that has remarkable contributions in addressing the challenges of information technology. It has introduced a new trend in hardware as well as in software. Efforts that have been made in this context led to introduce a new foundation, both for compilers and processors. In this report we study different techniques used for sequential decomposition of mappings without using extra variables. We focus on finding and improving these techniques of computations. Especially, we are interested in developing methods and efficient heuristic algorithms to find the decompositions and implementing these methods in particular cases. We want to implement these methods in a compiler with an aim of optimizing code in machine language. It is always possible to calculate an operation related to K registers by a sequence of assignments using only these K registers. We verified the results and introduced new methods. We described In Situ computation of linear mapping by a sequence of linear assignments over the set of integers and investigated bound for the algorithm. We introduced a method for the case of boolean bijective mappings via algebraic operations over polynomials in GF(2). We implemented these methods using Maple
RR-7076.pdf (634.14 Ko) Télécharger le fichier
Dates and versions
inria-00428722 , version 1 (29-10-2009)
Identifiers
  • HAL Id : inria-00428722 , version 1
Cite
Mumtaz Ahmad, Serge Burckel, Adam Cichon. Sequential decomposition of operations and compilers optimization. [Research Report] RR-7076, INRIA. 2009, pp.91. ⟨inria-00428722⟩
424 View
360 Download
Share
