Traffic Grooming in Bidirectional WDM Ring Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We study the minimization of ADMs (Add-Drop Multiplexers) in optical WDM bidirectional rings considering symmetric shortest path routing and all-to-all unitary requests. We precisely formulate the problem in terms of graph decompositions, and state a general lower bound for all the values of the grooming factor $C$ and $N$, the size of the ring. We first study exhaustively the cases $C=1$, $C = 2$, and $C=3$, providing improved lower bounds, optimal constructions for several infinite families, as well as asymptotically optimal constructions and approximations. We then study the case $C>3$, focusing specifically on the case $C = k(k+1)/2$ for some $k \geq 1$. We give optimal decompositions for several congruence classes of $N$ using the existence of some combinatorial designs. We conclude with a comparison of the cost functions in unidirectional and bidirectional WDM rings.
RR-7080.pdf (311.63 Ko) Télécharger le fichier
inria-00429155 , version 1 (31-10-2009)
  • HAL Id : inria-00429155 , version 1
  • ARXIV : 0911.0140
Jean-Claude Bermond, Xavier Muñoz. Traffic Grooming in Bidirectional WDM Ring Networks. [Research Report] RR-7080, INRIA. 2009, pp.33. ⟨inria-00429155⟩
330 Consultations
306 Téléchargements
